Cam size help and Parts list
Old 06-23-2013, 11:38 AM
White94Bird's Avatar
Default Cam size help and Parts list
I'm thinking of the TSP 233/239 .595/.603 with springs and harder pushrods (7.375 or 7.4"?)
Stuck on rather single or dual valve springs?
Oil pump? A must? And which one?
And I'm guessing a stall will be required? And Size with stock gears, 3.23s. Thinking 3000-3200??
Tune, duh?
Stock injectors should be fine, correct?
What else?
This is a weekend car, not DD or Race car. Still want to be able to drive through downtown and not worry about anything.
Old 06-23-2013, 11:42 AM
Darkman's Avatar
Melling 10296 Oil Pump, Timing Chain.
Old 06-23-2013, 11:45 AM
OO yeah forgot about the chain. A LS2 HD fine?
Old 06-23-2013, 11:50 AM
leeluther252's Avatar
you need to run a double spring with that cam. You will most likely need a 7.400 pushrod. Its always good to measure though.
A Melling high pressure or a ported ls6 would both work just fine.
You need a 3200 stall for that cam.
Tuning is a must.
Ls2 chain will also work just fine.
Old 06-23-2013, 11:52 AM
Darkman's Avatar
The LS2 is the standard upgrade and should work. If you've got the coin I would spring for the Katech C5-R (Tick Performance, among others, have them.)
Old 06-23-2013, 11:57 AM
Tuning is a must.
Ok, Ls2 chain it is.
I heard you have to mill soem of your timing cover to run a melling?
A 3200 sounds good, and now to find a tuner.
Old 06-23-2013, 11:59 AM
The only issue that I've had with running a melling is with a double roller. You can always run the ported pump, its a good setup, just costs more.
Old 06-23-2013, 12:07 PM
FIVEPOINT7's Avatar
3200 is a bit on the low side for that cam, I'd go 3600 or 4k. I also have that cam, went with bigger injectors. Pushrods you'll have to measure, oil pump is up to you, my stock one was completely fine so I left it, do the chain, and dual .650 springs.
Old 06-23-2013, 12:10 PM
being a 98 I would feel safer with an aftermarket pump. And What stall did you run?
You ran it at the track or dyno yet?
So a single roller and a meiling is fine?
Old 06-23-2013, 01:20 PM
Darkman's Avatar
Yes, it is.
Old 06-23-2013, 03:04 PM
What about lifters? Stockers fine?
Old 06-23-2013, 03:24 PM
Darkman's Avatar
The current "stocker" replacement is the LS7 lifter which is fine. Replacing the lifters requires pulling the heads, which is only necessary if the current lifters have a lot of miles (60k miles is the rule of thumb I hear most often).
Old 06-23-2013, 03:57 PM
i got 78000... dang
Old 06-23-2013, 04:27 PM
Darkman's Avatar
i got 78000... dang
Now you did it. You'll need a set of CNC'd 243s to cover up those new lifters properly.
Old 06-23-2013, 06:20 PM
I agree! But ain't that rich.
Old 06-23-2013, 06:25 PM
Super Hulk Smash
JakeFusion's Avatar
Sigh.
Go to Tick Performance and get a Stage 2 or Stage 3 TorqueMax cam. Newer lobes from Comp - not the XE-R lobes from a decade ago that beat the **** out of your valvetrain. Plus, the 233/239 is on a 112+0. That's going to produce no bottom end on an otherwise stock motor. You want something in the 227/235 110 range like the Stage 2 from Tick.
Or, if you want to spend a little more, talk to Geoff @ EPS and get something custom ground using EPS lobes. The 226/234 111 or so would make for a nice street car.
I'd also run 11/32nd pushrods, BTR Platinum Dual Springs, Melling Oil Pump + Katech C5R Chain or the SLP Double Chain + Ported Pump combo.
Stall - Talk to Chris @ CircleD. The 3C or 4C would work well for you in the 3600-3800 range.
Old 06-23-2013, 06:26 PM
Darkman's Avatar
Well it is not a DD or Race Car, so I would probably go with existing lifters.
Old 06-23-2013, 06:46 PM
The same board ******, always come into peoples threads and instead of answering their questions, try to push their opinions on people. I can tell you first hand you can make great power from the 233/239 and still retain great drivability. If that's the cam you want to run it, run it. If not, don't. That cam has been used countless times without issues. I myself used it in a daily driver low 11 sec 6speed car for a good 20k miles without issues. Not bragging, just pointing out it can be done. Good springs, good geometry, and good oil is key. Of course their are other cams out there that can also make good power. Its about your whole setup, not just the cam.
Old 06-23-2013, 07:13 PM
I like the cam because it is proven and around what I want out of a cam. i just need more to make sure i get everything put together right without having to worry that it was thrown together.
Old 06-23-2013, 07:36 PM
Darkman's Avatar
The TSP website indicates that your cam can use with beehive or double valve springs. Additionally, the Comp Cam catalog indicates that similar cams (in terms of duration and lift) with XER lobes should use Comp 921 valve springs. Comp 921 valve springs have a spring rate of 408 pounds and an open spring pressure of 400 pounds. I may be wrong, but I would not expect a cam that can be controlled with beehive valve springs, or double valves springs with 400 pounds of open spring pressure to be all that devastating to the rest of the valvetrain.
Quick Reply: Cam size help and Parts list
