Smoken!!!
Smoken!!!
No this in not a burn out video. Im having another issue of smoking. First I had bad valve stem seals. On hot starts id smoke like a train. Thats fixed and hot starts a from what i can tell are clean .On the other hand say im out running around and i decide to get on it. Like a good pull from 2nd into third to about 4500. Then i let off in gear and here comes the smoke. Its from what i can see whiteish with some blue. Kinda grey i guess. Coolant and oil levels have been stable. not losing any of each that can be noticed. Like i said its only when you let off after doing a hard pull. Which honestly i dont do very often. What could this be? Any help would be great.
THANK YOU
Jim
THANK YOU
Jim
Very well could be. I just have the stock valve stems. I heard of people "upgrading" to another style. Will have to look into that. Could bad valve guides be an issue here? When i changed the seals the first time I used a dial indicator and tested the for wear but nothing caught my attention and the tests resulted in number that were in spec.
No i have holly valve covers. Each just have a nipple that a standard 3/8 ID hose slips over. Had one running into the throttel body and one into the intake right behind the throttel body. I even tried just letting them vent open in the motor bay and plugging off the ports on the intake and throttel body. Its still the same.
