Oil leaking from both head gaskets (but no anti-freeze leak!)
Title says it all.
I have fresh (unburnt) oil leaking onto a/c compressor and dripping down to the garage floor. I cannot get a good view of the passenger side head at the front of the block where the majority of the oil seems to be bleeding from. I can also see both gaskets have fresh oil coating them and slightly seeping as well when viewed from underneath on a lift.
There is no evidence of coolant leaking. The engine is not over heating and there is plenty of coolant in the reserve tank cold & hot.
The engine is running strong; with no tell tail signs of an issue.
So how it possible for oil to be leaking from my heads with no coolant leaking out at the same time?
Thoughts?
Thoughts?
I have no error codes for PCV problems and my catch can is empty.
My oil pressure gauge stays within normal operating ranges from idle to WOT; if the port is leaking would the gauge still operate properly?
