what rocker arms to buy?
Im gona be doing some 243's soon I have a comp 224/224/565/565/110lsa now I wanted to change out the rockers but do I go with a 1.7 or 1.8 rocker and also pushrods what size would be the best. Please let me know anyone thanks
Yea I'd pass in the higher ratio rockers as the benefit of slightly higher lift isn't worth valavtrain stability, the higher ratio is for ls7s and people who are too lazy to swap the stock cam...the cam itself will give you what you want
As far as roller tip rockers I wouldn't go that route either unless you are going to take time to make sure your wipe pattern is right on...do yourself a favor and do the the noon upgrade like the other guy said and you can spin it as high as your heart content...good luck bro and enjoy that cam!
All motor probably 380-390rwhp with good tune if you have supporting bolt ons and then obviously around 500rwhp with the 150 shot, make sure you have an aftermarket fuel pump or booster bc I've always been told its a rule of thumb not to go above a 125 shot on the stock pump, you especially since you will have a cam and good flowing heads, your tuner will be able to tell you the biggest shot you can handle with stock pump after dynoing all motor
Oh yeah I got a racetronix with the hot wire kit and full exhaust with a slp lm1 I just got me some 42lb green tops and im looking to get an after market fuel rail I was thinking of some d585 coils but I think the stockers should be fine for now and for now im just gona send my Ecu to frost to get a tune
