one dead cyl.. hear a tapping noise anyway to check lifters ?
got some LS6 lifters all new in the car about 15 k ago....if they are bad what is the best to replace them with ? can you check valve lift with out the engine running with hydraulic lifters ?
you can pull the plugs and the valve covers ,and slowly rotate the engine with a big ratchet on the crank bolt.have a friend rotate the crank while you watch the rocker arms move.
