Re-Use bolts
Old 07-17-2013, 08:27 PM
Rolandt's Avatar
Default Re-Use bolts
I'm changing my heads and some one told me that I have to buy all new bolts that come out the block, true or false?
Old 07-17-2013, 08:35 PM
Super Hulk Smash
JakeFusion's Avatar
True.
The stock GM bolts are torque to yield. Once you install them, you angle torque them to get final stretch. Once they are stretched, you cannot re-stretch them.
Get ARP bolts or be a baller and get ARP studs.
Old 07-17-2013, 09:40 PM
batboy's Avatar
True, GM bolts are one time use and so are the head gaskets.
Old 07-18-2013, 12:12 AM
wildcamaro's Avatar
Only the head bolts are one time use, sometimes you can re use head gaskets but I wouldn't recommend it
Old 07-18-2013, 01:01 AM
01WS6/tamu's Avatar
If you still have stock manifolds replace the bolts it's cheap cya insurance. I chunk them when we do them at work had a few here and there break off after pulling the heads while re torquing them
Old 07-18-2013, 06:50 AM
FIVEPOINT7's Avatar
I bought ARP bolts, you don't have to stretch them, they just get torqued and you're done, plus those ARE reuseable unlike the stock ones so I never have to buy another set.
Old 07-18-2013, 08:10 AM
LS1-450's Avatar
Great choice. Be sure to get ALL of the fluid out of the bolt holes before installing new bolts. If you don't, the trapped fluid will expand & can crack the block. A little copper spray on the head gaskets doesn't hurt either.
Old 07-18-2013, 08:21 AM
onefast84's Avatar
You can also get studs from alper motorsports, or ebay for like $60. I use them, along with many others on here with good luck!!
Old 07-18-2013, 08:45 AM
ckpitt55's Avatar
arp hardware is worth its weight in gold - one of the best investments you can make if you plan on doing any kind of work, be it maintenance or mods.
unless you're going to be rebuilding the shortblock though, I would stick with arp bolts vs. the studs. the studs load the block differently and could potentially alter your bore shape. most competent machine shops will ask you for the hardware you'll be using in the build and do the machine work with those to compensate.
Old 07-18-2013, 12:34 PM
wildcamaro's Avatar
^^^good info...some don't realize this, it's especially import at on main cap studs, you must get them line honed in order to keep round
Old 07-18-2013, 12:40 PM
TurboBuick6's Avatar
Learned this the hard way when I was a kid with my first GN. Got em all torqued till the last one. Wrench never clicked. Do'h!
Old 07-18-2013, 02:41 PM
Rolandt's Avatar
Thanks for all the information I was thinking of getting this yes or no?
http://www.summitracing.com/parts/nal-12499217
Old 07-18-2013, 03:00 PM
batboy's Avatar
That kit from summit is okay, but it comes with a lot of gaskets that don't need to be replaced. For example the valve cover gaskets and intake gaskets can be reused. The manifold/header gaskets can also be reused if they are undamaged and in good condition.
You want the earlier style bolts if you have a pre-2004 LS1.
http://texas-speed.com/p-1697-gm-gen...-per-head.aspx
The GM MLS gaskets seal up the best.
http://texas-speed.com/p-209-gm-ls1-...d-gaskets.aspx
Old 07-18-2013, 03:21 PM
Rolandt's Avatar
So the bolts in the kit aren't the right ones, I'm pretty much going new with everything, but I didn't know you couldnt reuse the bolts
Old 07-18-2013, 05:16 PM
wildcamaro's Avatar
That kit will work for you, best bang for your buck and all quality factory gaskets and bolts
Old 07-18-2013, 05:28 PM
batboy's Avatar
The summit kit doesn't list early vs. later LS1; although, the photo shows 3 different length bolts which is correct (assuming the photo is what you are really getting). I've ordered from Texas Speed many times and trust them. Besides, you'll save a few bucks.
Old 07-18-2013, 05:40 PM
dcam503's Avatar
make sure you get the right bolts/studs.. I just about made a $400 mistake and got studs that were for newer engines than mine, i caught it in the checkout..
Old 07-19-2013, 01:09 AM
Rolandt's Avatar
I'm gonna get new heads and change out my cam so can anyone give a LINK for a good set of the gaskets and bolts I need I'd really appreciate it.
Old 07-19-2013, 09:28 AM
PREDATOR-Z's Avatar
http://www.tickperformance.com/gaskets-bolts/
Old 07-19-2013, 11:09 AM
batboy's Avatar
Didn't like my links?
Quick Reply: Re-Use bolts
