Decked block and heads still need 7.400" pushrods???
Aluminum LS1 block has been decked .015". Stock casting 241s were decked .015". New 2.02"-1.60" valves, Cometic .051" head gaskets, COMP XER 281, Scorpion 1.7 roller rockers, COMP 850 lifters, Scorpion 7.400" pushrods, new AC Delco rocker bolts. I'm getting between 1 1/2 - 1 3/4 turn past 0 lash @ 22 foot pounds. According to specs, I'm within the 1 1/4-1 3/4 range. Just curious as to why I'm not needing shorter pushrods???
Frank
Frank
Did they re-do the valve seats when they worked on the heads? Are they stock GM valves or aftermarket? If they used aftermarket valves or worked the seats it may change the pushrod requirement.
Also if they did do this, check several pushrods for length, not just #1, just to make sure you get a consistent length.
If I understand this correctly, each full turn of the bolt is .047". 1 5/8 turns would equal .076" preload. Will that preload be OK for a cam that makes power to 7200 RPMs?
Frank
Frank
If he used Ferrea valves, then the stems may be shorter than GM and that may be why you are getting these values. If you have the Ferrea part number and a stock GM valve you could verify it if you wanted to but not necessary other than curiosity.
Finish in the gasket surface looks real nice by the way.
