LS1 Aluminum Safe cleaning solvents
Old 07-29-2013, 09:53 AM
Pbeyer2010's Avatar
Default LS1 Aluminum Safe cleaning solvents
Hi guys,
As the title suggests, what solvents are safe to use with the ls1 block and heads ?. I am looking to make a parts washer and soak the block , heads and misc pieces to remove grime. What products can i use and what works best ?
Thanks,
Phil
Old 07-29-2013, 10:09 AM
Grimes's Avatar
you can use simple green, as long as you rinse all the chemical off afterwards with water. I've used it when washing down my engine bay. Nice thing about simple green is that it is not a super harsh chemical that you'll have to worry about getting sick from.
Old 07-29-2013, 10:54 AM
Pbeyer2010's Avatar
Thanks Grimes,
From what i have heard, simple green may be a no-no with the aluminum block and can discolor aluminum. I was also looking at a safe solvent like "purple power". Do you have extensive experience using the simple green with the aluminum components?
-Phil
Old 07-29-2013, 10:55 AM
Pbeyer2010's Avatar
to clarify, i am looking to submerge the parts as the block is out and striped down.
Old 08-01-2013, 03:13 PM
Grimes's Avatar
If you leave it on, i think it can discolor, but I have been using it for years with no ill effects. Have not heard of purple powder....
Old 08-01-2013, 03:37 PM
sherman8r's Avatar
purple power and the purple zep degreaser are the same thing and they will both make the aluminum turn darker. both of those need to be rinsed after application as well. i have always had good luck with solvent based stuff. and it works better in my opinion.
Old 08-01-2013, 06:32 PM
schnellttz06's Avatar
I think by the time you get enough solvent of any kind to soak a block, you could have just paid a machine shop to dip it for you. But I like to use Marine Clean for mine, it will turn the aluminum darker if you leave it too long, but works great if you wanna paint your covers.
Old 09-16-2013, 05:39 PM
TipsyMcStagger's Avatar
Pine-Sol
Have a look here.
Tipsy
Old 09-16-2013, 06:21 PM
wildcamaro's Avatar
Not sure but whatever shops use in their hot tank works awesome or even sand/soda blasting, but you gotta do a lot of cleanup after that
Old 09-16-2013, 06:25 PM
RPM Graphics's Avatar
i used some Eagle-1 mag cleaner.
Old 09-16-2013, 07:36 PM
The_Bishop's Avatar
I'll second the Pine-Sol. Worked wonders on a set of heavily caked up valve covers I pulled off a van motor.
Old 09-16-2013, 08:37 PM
S10xGN's Avatar
Our local shop uses Varsol, it's like a light kerosene...
Quick Reply: LS1 Aluminum Safe cleaning solvents
