Longevity of higher 11:1 and 11:5 compression engines
Old 08-06-2013, 11:38 AM
Oldscoolnew's Avatar
Default Longevity of higher 11:1 and 11:5 compression engines
Hey guys I'm building an lq4 and 243 heads and flat top pistons I want to mill the heads .030 to attain higher compression of 11:1. Just wondering how many miles u guys have on these engines? Worried about detonation or blowing a head gasket.
Old 08-06-2013, 11:46 AM
PREDATOR-Z's Avatar
For Detonation you have to pay attention to DCR not as much SCR. For 11:1 and 11.5:1 SCR you'll need to run 92/93 octane and have a came with less than 8.5 DCR.
Use MLS gaskets with no more than .045 quench and use proper plugs. (colder than stock).
Old 08-06-2013, 11:53 AM
redtan's Avatar
First of all, that all can be controlled by having a proper tune and using good 93 octane gas.
Second of all 11:1 compression is not that high that you have to worry about longevity. LS2s come with 10.9:1 compression and those can run on even 91 octane with the stock tune.
Heck, even a 12:1 compression engine will be just fine if it has a good tune to combat detonation.
Old 08-06-2013, 08:36 PM
S10xGN's Avatar
Are you talking about keeping the stock pistons? Not sure I'd go there personally, they're weak on a good day. With increased compression, everything has to be perfect or you're asking for trouble...
Old 08-07-2013, 08:33 AM
2000ultraZ1911's Avatar
redtan 10:53 AM Yesterday
Originally Posted by : Worried about detonation or blowing a head gasket. First of all, that all can be controlled by having a proper tune and using good 93 octane gas.
^^ I'd say he's right on.
Old 08-07-2013, 04:38 PM
2000PewterT/A's Avatar
I know of countless motors running 11.1 and above for a long time with no problems. As long as you have the right parts and a good tune you should be fine.
Old 08-07-2013, 04:48 PM
SNLPerformance's Avatar
LS7 comes with 11:1 compression from the factory, as mentioned DCR is more important as well as the tune. I would run a .040" head gasket before milling as that will increase compression and provide better quench without hurting airflow.
Old 08-27-2013, 09:49 PM
My DCR at 11:1 with the cam I purchased is 8.79:1 is this going to be an issue?
Old 08-30-2013, 07:02 AM
mark21742's Avatar
Most people say the max is 8.5:1 for 92/93 pump gas but ive seen a few running as high as 9.0:1. Just be careful with your tune and you might pull it off.
Im running 12.5:1 scr with a safe 8.22:1 dcr in my 408
Old 08-30-2013, 12:29 PM
96lt4c4's Avatar
My compression is 11.8 my DCR is 8.5. I have no knock. Pretty much a stock LS1 timing table. Max timing at WOT is 28 degrees. Thinking of doing a cam swap this winter that will knock it down to about 8.
Quick Reply: Longevity of higher 11:1 and 11:5 compression engines
