Removing dipstick hole plug from GTO LS1 block?
Old 08-08-2013, 09:04 AM
Cobra4B's Avatar
Default Removing dipstick hole plug from GTO LS1 block?
EDIT - That was utterly simple. Complete access and taps right out with basic punch.
Converting a new LS1 GTO crate engine into a LS6 for my car. I need to get that freeze plug out to use my LS6 dipstick tube. I have the engine on a stand and haven't put the pan on yet. Is it as simple as hitting it out with a punch from the back side?
Thanks,
Brian
Old 08-08-2013, 09:44 AM
wildcamaro's Avatar
Yea if you can hit from backside that's ur best shot other than drilling small hole in it (cover from backside of course) then run a bigger screw in then put a pair of vice grips and the slap vice grips with hammer...punching out backside sounds safer though
Quick Reply: Removing dipstick hole plug from GTO LS1 block?
