Accusump & Sensor Adapters for LS Engines
LS1Tech Sponsor
Improved Racing has released adapters for connecting an Accusump + 2 sensors, or 3 sensors to all LS engines.
These adapters bolt to the factory oil bypass location just above the oil filter.
Accusump Adapter for LS Engine
Part No. EGM-116
Features a -8AN female O-ring boss port and includes an adapter for -8AN or -10AN lines for Accusump connection. Also has two 1/8" NPT ports for oil pressure or temperature sensors, or for a turbo oil supply line. 1/8" NPT plugs are included for unused ports.
Price: $89.00 including -8AN or -10AN adapter fitting
Link: http://www.improvedracing.com/oil-ad...ine-p-339.html
Oil Sensor / Turbo Feed Adapter for LS Engine
Part No. EGM-118
Features three 1/8" NPT ports for oil pressure or temperature sensors, and/or for a turbo oil supply line. 1/8" NPT plugs are included for unused ports.
Price: $79.00
Link: http://www.improvedracing.com/oil-ad...ted-p-341.html
These parts are also available in versions with sensor ports for the factory C5 Corvette oil temperature sensor. Part numbers are EGM-117 and EGM-119.
Feel free to post up if there are any questions.
Part No. EGM-116
Part No. EGM-118
Price: $79.00
I was looking at these this week for an accumulator for a rock crawler. I also cam across a basic fitting and started searching to see if your style is more beneficial than just the oil galley fitting like this one?
http://rightsideperformance.com/i-11...y-fitting.html
LS1Tech Sponsor
We sell those galley fittings as well, but we don't recommend them because they use unfiltered oil. This introduces the risk of contaminants in the oil damaging or reducing the life of your Accusump. All of the oil coming out of our adapter is filtered oil. You also have the benefit of being able to easily add two sensors.
LS1Tech Sponsor
The only other option aside from our adapter would be to use the galley port behind the intake, where the oil pressure sensor is.
