whats good clearances in rod bearings and mains?
Old 08-14-2013, 10:14 PM
mannyman84's Avatar
Default whats good clearances in rod bearings and mains?
An engine builder told me I want to be any were between .02 to .04.
Opinions on this? Also are king bearings good?
Old 08-14-2013, 10:35 PM
wildcamaro's Avatar
Def dont want 0.020" lol that will be ZERO oil pressure...more like 0.002-0.0025" on the mains...that's for a street motor, clearances increase if building a race engine
Old 08-14-2013, 10:51 PM
SOHCNightmare's Avatar
Lol. Those zeros make the world of difference.
What about rod bearing clearances? I was wondering the same.
Old 08-15-2013, 12:06 AM
ckpitt55's Avatar
depends on your application. n/a? boost? spray?
If n/a - 0.0017 - 0.002" is good for mains. at a certain point though how the crank feels with the caps torqued down is more important than a few tenths here or there. You want nice and easy rotation with no binding. Mine had less than 20 in-lbs resistance with engine oil as a lubricant. 0.0018" - 0.0022" is good for rods. you can run on the tight side if you're confident that all your bores are round, run on the looser side if you're not as confident and / or it's a high output build.
what's right isn't set in stone, you and/or your machinist will have to sit down and figure out whats ideal for your setup. my 0.02.
Old 08-15-2013, 12:54 AM
mannyman84's Avatar
Sorry I knew I missed a zero in there just wasn't sure lol
Old 08-15-2013, 12:57 AM
mannyman84's Avatar
Thanks for the input guys. Ill be running a big shot of n2o that's why
Old 08-15-2013, 04:59 AM
RezinTexas's Avatar
if aluminum block, go with what ckpitt said. if iron block, you can go up to 0.0030 on the mains.
For the rods (doesn't matter what block material), I'm running up to 0.0028". Most people use less clearance, however I still have excellent oil pressure (50-60 at hot idle).
Old 08-15-2013, 09:54 AM
schnellttz06's Avatar
King bearings are pretty much top of the line by the way, I put the tri-metal ones in mine. Ive been also been told that they are made so that if you do ever spin a bearing, your crank wont get chewed up.
Old 08-15-2013, 12:49 PM
2000PewterT/A's Avatar
0018-.0020 for the mains and .0020-.0022 is what I am running with no issues.
Old 08-15-2013, 04:46 PM
KCS
Moderator
KCS's Avatar
.001" of clearance per 1" of shaft diameter is a good rule of thumb.
Old 08-15-2013, 05:11 PM
^^ Good to know
Old 08-15-2013, 11:27 PM
mannyman84's Avatar
Sorry for my ignorance. But you mean crank shaft? And what diameter am I measuring?
Old 08-15-2013, 11:30 PM
mannyman84's Avatar
This will be my first build. I feel very confident building it but I need to know little details of smaller things which could be a big deal when its running
Old 08-16-2013, 10:02 AM
You should get the book on how to rebuild LS1 engines, it goes over lots of little details that you could easily miss. And it expains how bearing clearances correlate to oil viscosity, i.e. tighter bearings equals thinner oil. And make sure you get a oil pump primer and dont listen to all the BS about cranking the engine with the coils unplugged until you see pressure, worst thing to do since it still is wearing on your brand new bearings. Plus you can see how your oil pressure is before your install the engine and identify problems before its too late.
Old 08-16-2013, 03:00 PM
Ironfreak's Avatar
Lots of good info in this thread guys, I'm in the same process with my motor and was about to ask these questions. Is there a specific book you'd recommend over others. I'm always willing to drop some cash on valuable knowledge.
Old 08-16-2013, 03:04 PM
KCS
Moderator
KCS's Avatar
Camshaft too. You should be measuring the OD of the main, rod, and cam journals and compare with the ID of the bearing install and fasteners torqued to spec. You should also measure the main and rod bores without bearings to verify they are round and within spec. Too big, and you lose the critical bearing crush that keeps the bearings from spinning in the bores.
Old 08-16-2013, 04:20 PM
wildcamaro's Avatar
A good bore gauge and set of micrometers are good tools to have for a bottom end build...
Old 08-17-2013, 12:17 AM
mannyman84's Avatar
Awesome, guys. Thanks to all who replied. Very very good info!
Ill be purchasing some good quality measuring tools this weekend to make sure everything is up to par.
Old 05-19-2014, 10:57 PM
mannyman84's Avatar
UPDATE: I bought standard clevite H tri metal bearings. From the front to the back I got
.0020
.0024
.0028
.0026
.0028
Old 05-19-2014, 10:59 PM
mannyman84's Avatar
This is on the mains, that first bearing worries me on how tight it is. Is it OK to try it on under another main cap and see how it does?
Quick Reply: whats good clearances in rod bearings and mains?
