too much head for a 346?
Old 08-16-2013, 12:56 AM
Orry Bynum's Avatar
Default too much head for a 346?
hey so ive been debating what to start my car with its an a4 with yank 3600, ls6 intake, pace setter lt ory and a cut out.... but i am planning on getting the tsp 233/239 cam then getting the prc as cast 225 heads which seem similar to the prc ls6 stage 3 heads then i want the fast 92 does that seem like too much? is there too much? and im open to any other different combinations....
thanks for the help!!!
Old 08-16-2013, 08:06 AM
00Vette04GTO's Avatar
You can never have too much head
No, seriously... You can't.
I have Trick Flow 220's and my car (similar setup to what ur thinking) just kept eating the timing and fuel... That's a good thing.
So long as you can move the air, combust the air, fuel the air, spark the air, and get the air out to start over - you are going to make power. So it is nice to have good heads and not have a problem with air delivery/removal. (normal choke point for a lot of ppl)
Old 08-16-2013, 08:16 AM
zzcamaro00's Avatar
from what i have read, i hear the tsp as cast 225 are a good option, more bang less buck
Old 08-16-2013, 08:25 AM
mchicia1's Avatar
I put on ls3 small bores (as cast, just milled) and an ls3 intake and gained 45 rwhp, same dyno, same correction and that was with LS7 manifolds, not headers. I would imagine with headers you will see more gain. They are huge heads for a 5.7, but they worked fine. Very affordable too and an ls3 intake is like a fast already for a fraction of the cost with injectors and rail usually.
There is something to be said about buying new heads vs ported used castings.
Old 08-16-2013, 08:49 AM
Rise of the Phoenix's Avatar
OP, you'll be fine with those heads. They were made for the 346.
Old 08-16-2013, 12:55 PM
Z28SteveA4's Avatar
those heads will be fine. like stated above you can never have to much for heads. heads are the most important objest on your motor to make good power
Old 08-16-2013, 01:38 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
You will be very happy with that combo. That head flows well and makes good power, without being so big it kills low end velocity.
Old 08-16-2013, 02:03 PM
Orry Bynum's Avatar
great thanks everyone im glad to hear that....
what size chamber would be ideal..... i know smaller will give more compression so i was going with the 62cc chamber vs 68cc.... is 62 the factor chamber size, how will it affect my compression ratio
i would like to know as much as i can before i make my finally decision
Old 08-16-2013, 05:02 PM
If the block is stock go with the 62cc and we could even take then down a little. 62cc should put you about 10.8
Quick Reply: too much head for a 346?
