ls2 short block with stock ls1 parts
Hey gear heads, I have a 2000 z28 camaro with a basebalI size hole where the dip stick used to be. I also have a ls2 short block out of a corvette 2005 that I plan on using. I know that this is a direct swap on the top end but what problems should I encounter. What advise can you guy's give me. Also I need a oil pan if you guys have one laying around, I would consider buying it.
Thanks.
Thanks.
