ls1 block repair clutch gernaded
Old 08-23-2013, 08:54 AM
99427camaro's Avatar
Default ls1 block repair clutch gernaded
[/IMG]well the worst has happened, my clutch let go at about 6800 rpm and all hell broke lose. The presser plate almost escaped from my quick time bell housing, thank god it did not! but in the proses it broke my trans off of my block cracking all of the mount holes. ripping the starter off of the block and took a chunk with it. the big problem here is that i have darton sleeves in this block so that is 1400 in machine work alone! can this be fixed? is there any shops out there fixing these?
https://ls1tech.com/forums/picture.p...ctureid=103979
https://ls1tech.com/forums/picture.p...ctureid=103978
Attached Thumbnails ls1 block repair clutch gernaded-re-sized.jpg   ls1 block repair clutch gernaded-bill.jpg
Old 08-23-2013, 09:01 AM
badazz81z28's Avatar
If it broke all the mounting holes for the bell? I would cut your losses....
Old 08-23-2013, 11:14 AM
WS.SIX's Avatar
Ouch... Wheres the carnage pics!?
Old 08-23-2013, 01:46 PM
i could not get the picks to load
Old 08-23-2013, 02:06 PM
Old 08-23-2013, 05:51 PM
TurbopigB4C's Avatar
That hurts just looking at it. I wonder if the same carnage to the block would have occurred if it was an iron block. Was it a GM clutch or an aftermarket?
Old 08-23-2013, 06:44 PM
wildcamaro's Avatar
Holy ****...I'd cut you your losses...even the best weld job won't be as strong as it was originally...could prob sell the block to someone who wants to salvage the sleeves or just bite bullet and get a new block and re use sleeves, if that's even possible
Old 08-23-2013, 08:15 PM
Probably not as bad, but iron isn't bullet proof either. It def would have cracked the block.
Old 08-23-2013, 08:34 PM
HeavyMetl's Avatar
What kind of clutch/flywheel? You just don't hear of this type of catastrophic failure very often.
Old 08-23-2013, 09:17 PM
older speck stage 3 in second gear went sideways in 1st grabbed second and thought the tires were spinning like they always do, nope bang then the lovely sound of a drive shaft in a safety loop. I am going to fix the block the is not a lot of load on holding them together because all of the force is rotational also i am going to add 2-3 mounts.
Old 08-23-2013, 09:23 PM
You say your are going to try and fix it? I would like to see the final product.
I'm kind of curious to know what went wrong. I don't think you will much success with the repair.
Old 08-23-2013, 09:45 PM
well it is the most inexpensive way, any other way is going to cost me 3k+ so ill give it a go and keep you all posted...
The reason i started this thread was to see if any one out there has done a repair to the block along these lines.
Also wanted to get so ooos and ahhhs on the carnage
Old 08-23-2013, 10:23 PM
I want to see more pics!!!! Is your engine forged or something??? You can definitely get a stock short block for quite less than $3K
Hell I just saw a complete LS2 on PT.com for $4k OBO
I just don't see how you are going to weld that block up and have the same strength as before plus alignment issue if you don't get the holes lined up perfect.
Old 08-23-2013, 11:42 PM
Old 08-23-2013, 11:51 PM
I have heard of this type of thing happening with Spec clutches in the dsm community but thats usually with 500whp and higher awd launches.
Old 08-23-2013, 11:54 PM
also i would like to keep the stock block in the car.
Old 08-23-2013, 11:58 PM
im 500 hp and have 235 tires out back
Old 08-24-2013, 12:10 AM
235? isn't that smaller than stock
Old 08-24-2013, 12:51 AM
yeah its late to many 315s out back haha
Old 08-24-2013, 02:17 AM
Redchevyman's Avatar
I hope it turns out good. Its always fun to fix stuff that people think is not fixable.
Quick Reply: ls1 block repair clutch gernaded
