LS6 intake on LQ4
Old 08-25-2013, 08:18 AM
biohazardbill's Avatar
Default LS6 intake on LQ4
I know people have done this swap before and I know I will have to modify the accessories, but my question is what other things will I run into with this swap. The truck intake hits my hood so I had to swap it out. When I got the LS6 intake the coolant crossover tube doesn't allow the intake to set properly. So now I have to get a new tube.
So what else am I going to run into so I can go ahead and get everything needed all at once. This is my first LS engine so please be patient
Old 08-25-2013, 09:51 AM
N20zuki's Avatar
What accessories are you running on the motor?
Old 08-25-2013, 11:15 AM
xxtremes33's Avatar
you need a different water pump. from what ive read the intake will hit the waterpump outlet. you can heat the tube and bend it out of the way also.
Old 08-25-2013, 11:16 AM
xxtremes33's Avatar
let me know how this goes for you. i am also looking to swap a lq4 into my car and will need a car manifold.
Old 08-25-2013, 02:58 PM
I will be running the holley accessory brackets. Not sure ifit will be spaced for the LS1 or LS6, either way will require a new water pump and crank pulley. I am more concerned about the little things that are unforeseen. The crossover coolant line as an example.
Old 08-25-2013, 05:55 PM
chrisfrost's Avatar
which injectors are You planning to run ?
Old 08-25-2013, 07:45 PM
Stock for now
Old 08-25-2013, 10:04 PM
Redbull87's Avatar
hard to say what you might run into because your using different accessories.when i swapped from my ls1 to the lq4 i was re-using everything off the ls1.only had to drill the block for the alternator bolt.shaving the bottom of the ls6 intake had no issues for the coolant lines as i choose not to do the rear blockoff plates
side note,i hope you got good tires..you will need them
Old 08-26-2013, 04:46 PM
Its funny you say that because my buddy who talked me into this said that I will be surprised by the power in these motors. I usually deal with mild build big blocks but in my current project the motor was just physically too big. So far I have spent more in getting this thing to fit right than in the motor itself lol.
Quick Reply: LS6 intake on LQ4
