Head swap, which headgasket!?
Old 08-29-2013, 01:14 PM
Camaro98Z/28's Avatar
Default Head swap, which headgasket!?
I have a 98 LS1 with the mods below
Im finally swapping out the junk 806 perimeter bolt heads to a set of 799 heads with the correct valve covers obviously.
I'm 99% sure I need to get the head gasket for the HEAD and not the motor, in which case I'm assuming getting a head gasket set for a 2002 Corvette (since they had identical 243 heads) is the way to go correct?
Thanks!
Old 08-29-2013, 01:28 PM
KCS
Moderator
KCS's Avatar
That should work!
Old 08-29-2013, 01:53 PM
Awesome
so these would be the ticket?
http://www.texas-speed.com/p-209-gm-...d-gaskets.aspx
Old 08-29-2013, 03:24 PM
b0b
b0b's Avatar
correct ^
Quick Reply: Head swap, which headgasket!?
