'77 Trans Am LQ4/T56 Build..H/C Opinions (pic heavy)
Old 08-30-2013, 12:59 PM
HartAttack's Avatar
Default '77 Trans Am LQ4/T56 Build..H/C Opinions (pic heavy)
Fella's,
I'm a long time member on here however life has put me out of the game for 4 years or so. I've gotten back into it pretty hard lately but wanted to get your build opinions for my project. I've changed motors three times now. First I had an LS1. Sold it, and now have both a 5.3 and 6.0. Bought everything around doing a 5.3 turbo build but now just want a stout N/A 6.0 that I swing some n20 on later.
I need your opinions on how to do the 6.0. I was planning on getting the Vengeance Vindicator cam for it, and keeping the ported 5.3 heads on it with the LS9 head gaskets, but I'm not sure what the hell the compression would be. Need your opinions on head/cam/gasket setups. Lots of people with the 6.0's mill there heads. Thanks in advance for your thoughts.
Mod list below.
Project is my 1977 Trans Am.
Current List of parts I have are:
Motor parts:
-90k LQ4 6.0(Denali pull out)/ However I also have a LM7 5.3 with a 224/224 cam. I just got the 6.0 because I wanted more N/A Power
-Three head options-ported 5.3 heads (exhaust side only)-243 heads-317 heads
-LS9 head gasket/ and all new bolts for the motor
-F-body oil pan/ New Ls6 oil pump/LS2 timing chain
-Brain Tooley Dual springs, Trunion upgraded rockers
-Typhoon polished 96mm intake with NW 102mm TB
-SLP UD Pulley
-DynoMax 1 7/8 Coated Long Tube Swap headers/True Duel 2.5 exhaust 40's Flowmasters
-F-body radiator
-IROC steering box upgrade
-green top 42lb injectors
-Brand new fuel tank/vette works bracket/4th gen bucket,Lonnies double pumper fuel pump with hobbs switch/99 C5 fuel filter/new fuel lines etc.
-Street and Performance custom made Wire Harness
-Tick Stage 2 built T-56/Tick Slave/Tick Master/Speed bleeder/Hurst short throw shifter
-Exedy dual disc clutch (pending deal with friend)
Some pic's of the car.
Family generations with the car my dad, me, and my son.
Old 08-30-2013, 01:03 PM
HartAttack's Avatar
Quick Reply: '77 Trans Am LQ4/T56 Build..H/C Opinions (pic heavy)
