Bolt Circle Diameter
Old 09-04-2013, 03:43 PM
vic_dahn's Avatar
Default Bolt Circle Diameter
Does anyone know the bolt circle Dia for the ls1? or even better if someone has a dimension'd print.
I can figure it out but just wanted to shoot the question out there before I did.
I am making a bore fixture for my flowbench going to use a standard size 3.779 bore ( I am running a 4.8l)
Old 09-05-2013, 12:15 PM
usdmholden's Avatar
What dimensions are you looking for? The nominal head bolt locations relative to the cylinder bore center?
I can take some measurements out of the CAD system tonight if so.
Old 09-05-2013, 08:33 PM
vic_dahn's Avatar
Yes in relation to the bore. That would be a big help.
Thank you!
Vic
Old 09-05-2013, 08:42 PM
usdmholden's Avatar
This is an LS3 but the centers are all the same.
File Type: pdf
Quick Reply: Bolt Circle Diameter
