lq4 cam too big?
lq4 cam too big?
Hey tech,
I found a smoking deal on a used HKE cam that im considering. What im wondering is if its too big, not a good idea, or just better off going another route. My build as it sits is this:
99 lq4
4.030 forged flat mahle pistons w/valve reliefs
243 heads off of gto with steel valves. (bought valves separate)
ls6 intake
ported throttle body
Stock rods and crank (will be balanced)
Th400 3500 stall.
Eventually 100-150 wet shot
Dont really care about driveablility, will be street strip build.
Specs of cam are 243/255 112+2 lsa .624 lift.
The owner said that it was in a 403 ls2 based stroker and with 317s and ls1 intake made 488rwhp/450rwtq.
Will this cam work for me and my setup? or am i wasting my time and money.
99 lq4
ls6 intake
Th400 3500 stall.
What gears will you be running? It's a bit big, but then again if all you want is all out top end performance it may not be so bad then. If it were me i'd go with something a little smaller. The lift and LSA are good, but that damn duration is huge lol
Ended up buying the cam. GREAT DEAL. This thing barely looks like its been broken in! Anyway, I have no clue what size pushrods im going to need. Like i mentioned ill be using stock 243 heads, stock rockers, ls7 lifters, new trays and Brian Tooley .660 double springs. I figured the extra amount of lift those springs could handle would be fine for my .624 lift. What size pushrods will i need?
Thanks
Thanks
Thanks
Thanks
To find p-rod length, you'll need to measure with a p-rod meter.
