06 Silverado 5.3ls LSXRT intake requirements?
Old 09-13-2013, 04:34 PM
Need-More-Boost's Avatar
Default 06 Silverado 5.3ls LSXRT intake requirements?
Sup guys, my buddy has a 06 silverado with a 5.3, custom grind cam, similar to an MS3 cam & are deciding on doing a head and intake swap soon. looking to get a FAST intake (LSXRT)
Wanting to know on what else is going to be needed to doing the swap? Like what can be used again & what cant? Injectors,fuel rails etc. any advice helps thanks.!
Old 09-13-2013, 05:01 PM
RezinTexas's Avatar
check out post 14 of my build thread. Every setup is a little different, however you should find some answers here.
I would not recommend re-using the factory fuel rails (as I did). Get the billet rails with the correct hose fittings.
http://www.performancetrucks.net/for...2500-a-520418/
Old 09-13-2013, 10:42 PM
Sweet! Thanks!
Quick Reply: 06 Silverado 5.3ls LSXRT intake requirements?
