ms3, ported 243s, will i have to flycut
i have stock pistons on a stock shortblock, will I have to flycut my pistons to install my 243 heads and ms3 cam??
what if heads get milled .030?
With a cleanup cut and not much else (.005 or so) and a stock gasket you can probably get by, but with .030 milled off id say no way. That being said the only way to know is measure
An MS4 will barely hit... did this on a buddy's car with stock unmilled 853's. Never pulled the heads off so it had stock gaskets. Was such minimal contact that you could barely see the marks on a couple of the pistons.
Got a better description:??? It BARELY hit and there wasn't any material to go anywhere... nic'd the flattop just enough to create a small pit. I didn't setup/install the cam, only was there to see it taken apart after the eng. spun a rod bearing.
