Thoughts on heads
Thoughts on heads
Fti Ed Curtis dart 205 these heads have really good flow numbers with small intake runner.air speed should be very good with these heads
You could probably do all that with a set of heads on your car right now. If you must have an aftermarket casting the trickflow 220 as cast aren't bad for the money. Dart 205 heads can be good as well with minor work.
OP, are you saying that Ed Curtis ported the Dart 205cc heads? I know he did up a set of Dart 225cc heads for a guy with a GTO (saw the thread on one of the GTO forums) and the overall combo was pretty bad ***. You can also send the Dart heads into Advanced Induction for a 100% full CNC port job. I run the Advanced Induction Dart/RHS 223cc fully CNC'd heads and they are pretty stout. I've always heard the Dart heads are really good after a port job.
