Help with a motor...
I had a friend call me about a motor he had found for sale (I believe its on another forum). Hes a BBC guy but ive been trying to talk him into putting a LS in his el camino hes building. He sent me over the info on it but im not to much on engine internals other than cams. Hoping some others could chime in and give some more info and insight. looking for approx hp/tq numbers, reliability, quality of parts,cost to build, streetability etc. Hes not a drag racer just looking for a fun weekend cruiser. I know the cam is in the low 240's so its deff a top end max effort cam which may be a little much for what he needs. otherwise feel free to chime in. any info is better than no info.Thanks in advance
INFO:
LQ4 6.0 Iron block
.030 MAHLE FLAT TOP PISTONS,
TOTAL SEAL RINGS,
H BEAM RODS
BULLET HYDRALIC ROLLER CAM (believe he said low 240's)
COMP SHORT TRAVEL LIFTERS,
CLOYES DOUBLE ROLLER TIMING CHAIN,
LS3 HEADS NEW GM INTAKE VALVES,
MANLEY STAINLESS EXHAUST VALVES,
PAC SPRINGS,
SCORPION ROLLER ROCKERS,
TREND PUSHRODS-
INFO:
LQ4 6.0 Iron block
TOTAL SEAL RINGS,
H BEAM RODS
PAC SPRINGS,
TREND PUSHRODS-
what kind of compression would ls3 heads and flat tops make? im assuming this is a pump gas engine but I dont know for sure. Any idea what it would cost to build this? (block and internals plus heads ...no intake or oil pan or accessories)
