best street cam for ls1
Old 09-19-2013, 05:30 AM
devic's Avatar
Default best street cam for ls1
so i was looking into getting the tr224 114, untill i realized there is no more thunder racing
so any other suggestions ?
and plz post the requirements of the cam like if it need valve springs and such
looking to get something with about 30 hp gains, and a bit of a lope aslo the car is a A4
Old 09-19-2013, 06:47 AM
M6 Swap's Avatar
Call steve at lunati, he just sold me a cam and he's full of good info.
Old 09-19-2013, 07:01 AM
30th t/a's Avatar
Check out EPS. Alot of guys are running his cams and really like them. He can grind you any size cam you want.
If you want an off the shelf cam, the Texas Speed (TSP 228r) is a very popular choice. TSP also has a 224r cam. Both are really good.
Old 09-19-2013, 07:25 AM
Decadence75's Avatar
There are as many opinions as to which cam you should run as there are people on this site, haha. There are some good proven off the shelf grinds like the afore mentioned 224r & 228r from TSP. Martin@Tick just released some new grinds this year that are also proving to be some real power makers. If you want something custom the go to folks are usually going to be PatG, Geoff@EPS and Martin@Tick.
What are your goals for the car? Is it going to be a DD, a dragster, weekend warrior? And no matter what cam you go with, the valve springs are going to need replacing.
Old 09-19-2013, 02:52 PM
devic's Avatar
its going to be a DD and goals with the car is to get it to around 450 hp as i have time and money to get it there
Old 09-19-2013, 02:55 PM
99Bluz28's Avatar
Will it have L.T. headers, or stock exhaust manifolds/shorty headers?
With having a A4 trans I'd look at a stall first, something around a 3600 stall TC like a Yank or Circle D .
Old 09-19-2013, 03:23 PM
devic's Avatar
it will have long tube headers, and im doing the cam first because im having to fix some timing issues, so im just going to change everything out while i have it all torn down
Old 09-19-2013, 03:38 PM
99Bluz28's Avatar
You might want to really consider, putting the stock cam back in it until you can put in a high stall TC, otherwise with any cam even a 224/224 114lsa you're not going to enjoy it very much at all.
Old 09-19-2013, 03:44 PM
devic's Avatar
how will not having a TC effect driving ?
Old 09-19-2013, 03:57 PM
For starters, it will try and push through the brakes when you try to stop.
Old 09-19-2013, 08:05 PM
PREDATOR-Z's Avatar
Performance will suck and you'll be disappointed thinking you have the wrong cam while all along you need a TC.
But it is doable on the type of cam specs you are talking about. 224 on 114 LSA only has -4 degrees overlap so it will be possible to idle close to stock and not push through the brakes much.
Similar to a TR224 114 would be a
Comp Cam XER 224/224 .581/.581 114 +4 LSA (That is 110 ICL).
Old 09-19-2013, 11:22 PM
devic's Avatar
so there is timing already in the cam ?
Old 09-20-2013, 01:35 AM
PREDATOR-Z's Avatar
Yes....... and to make it easy for you the cam specs I gave you are same as TSP 224r on 114 LSA.
Old 09-20-2013, 07:40 AM
TT427's Avatar
You might want to read this and look at the graphs contained within. http://www.hotrod.com/techarticles/e...2/viewall.html
I know its with the square port heads but even the smallest cam made more power everywhere. So if you are not keen on getting a stalled converter, something like the crane, but on better lobes will be a good boost in power everywhere and carry the rpm better. Maybe do a smaller version of the "torque cam" on lsl/xfi lobes just ask someone to help get the valve events right. Just remember to take the article with a grain of salt I only post it for comparison of cams with progressively bigger durations and the affects on torque/power curve. I know upon first reading this I was impressed with the smallish cam averages.
Old 09-20-2013, 09:11 PM
xxtremes33's Avatar
im thinking about going with the tsp 228r. but im in a emissions county so i hear that i may have to go with the 224r to pass emissions.
Old 09-20-2013, 11:18 PM
Sales@Tick's Avatar
3200 9.5" stall from FTI.
Tick "SNS" Stage 1 camshaft. 223/227 .610"/.614" 111+2.
Gets my vote.
Old 09-22-2013, 10:31 AM
pcsmits1's Avatar
ive used the gmpp hot cam 2 times now and I have loved it I know im going to get flamed on but for a dd I don't think you can go wrong with it
Old 09-22-2013, 10:37 AM
It is a great street cam if you are running the stock converter. I, myself, am running that cam and since I put in a 4K converter a couple months ago I am disappointed with the car under part throttle circumstances. As it stands right now the car accelerates better under lockup conditions than unlocked at part throttle. So there is a point where the hotcam stops being great for a street car and becomes a hindrance.
Old 09-22-2013, 10:56 AM
pcsmits1's Avatar
Decadence75 I couldn't agree with you more!
Old 09-22-2013, 02:50 PM
PREDATOR-Z's Avatar
What work did you do to your tranny?
Quick Reply: best street cam for ls1
