Fuels injectors???
Fuels injectors???
I have a 2000 Camaro aluminum block LS1 5.7 engine with an older LS1 intake manifold (12560688) that I am going to be running with a ecu from PSI and either a stock fuel rail or aftermarket one that accepts stock injectors. My question is, which injectors are best to use for the price? I looked at the oem AC Delco ones but they seemed expensive compared to sets of 8 on ebay and what not. I don't want to trust an off brand since I don't know much about them or used ones unless someone with experience tells me different. Does anything on the ecu flash have to be changes when using other than stock injectors? Any help will be greatly appreciated.
