redesigned texas speed header install
got my TSP 1 3/4 headers installed this weekend. didn't ask what they have changed, figure they just making them better! mine slid right in without taking anything off. removed a couple heat shields, they went back in. the car was on ramps on top of three 2 x 12s. I changed the motor mounts while in there. still working on the TSP ory pipe. the pipes slide off the collector after using a half inch breaker bar on the clamps. didn't have my impact out there, try that tomorrow. biggest concern is no matter what I do the pipe is touching the bottom of car under the drivers side. looks like I will have to cut an inch or two off the end of the merge piece to get it into the I pipe. overhaul happy happy! what do you think about it touching car bout a foot off the collector? be alright?
i also istalled the TSP LT headers 1 3/4 with ORY pipe and TSP exhaust on my 98 TA. The driver side collector is hitting the floorboard a bit. But everything else seemed to bolt up perfectly....
