LS6 Valley Pan Question
Ok i just received a new LS6 valley cover or so I thought. I have now learned that GM actually has 2 versions of this valley cover, or so I have heard. Can someone that actually know for sure the difference between the 2please chime in. The P/N that I was told to order is 12575742 Below is a picture of the one that I received. Is this the correct one or not, if not please let me know what the correct one is, along with any other parts that I may need to purchase to make it work correctly and look correctly.
Thanks,
Eric
Thanks,
Eric
Yep, that is a stock LS1 replacement. What you want is the 04+ LS6 version which is the part number mentioned before. Scoggin Dickey has them for just under $100.
https://sdparts.com/details/gm-facto...parts/12577927
It will look like this:
That link to SDPC should come with everything you need to make the swap other than a small piece of 3/8" SAE30R6 hose which you can pick up at a local auto store. The only obstacle if you have an LS1 block would be that you need to cut a small piece out of the valley to make it fit.
you will need to plug the PCV outlets on the rear of your valve covers (and remove the plumbing);
you will need the short u-shaped hose to go from LS6 valley cover outlet to intake manifold PCV inlet;
you still need the short hose from the throttle body to the passenger side valve cover.
Hmm thats weird. I dont have a pcv valve on mine anymore. Just whats under the valley cover. And the little tube with the red cap that sticks out is routed into the manifold.
Hose routing is the same. You are just running a pcv system with zero restriction basically using an early LS6 valley without an external pcv valve inline with your hose from valley>intake. Getting oil inside your intake still? Try a PCV in line. If not you can just leave it.
This is correct, it will not eliminate it but it will help a bunch. Also, buy the GM U-shaped hose, it is a super tight bend and trying to make a straight hose work will not look near as good as their molded piece. Trust me I tried.
