what is this noise?
what is this noise?
What do you guys think?
Can you explain to me what your are hearing?
I was told i have nothing to worry about and truck runs very strong.
Sorry for the quality of video just recoreded on my phone. i don't have a garage.
thanks
Hard to say from the video but it sounds like a broken or damaged lifter to me. How does the oil look? How is the oil pressure? Any metal on the magnetic drain plug?
No way is that a normal engine noise UNLESS you are dealer trying to pass something off on someone.
Oil look fine when I changed it. Plug had no metal.
Oil pressure around 40 idle, up to 60 under throttle.
Listening to other videos sounds like lifter noise.
If I had liters replaced. What would you all recommend?
Thanks
Thanks
I was hoping more people would chime in.
Does ur motor make this noise or
Mine use too then I did this to fix it kinda of comments
Please help.
Isdlike get this fixed if its going to hurt the motor in the future.
I can try to take a better video if the wind is missing up the vids
The more I listen to other vids on you tube sounds like a lifter
Thanks
Please help.
Thanks
