Hooking up throttle cable from Ls1 to original 67 camaro
Old 10-20-2013, 03:12 PM
CamaroLance's Avatar
Question Hooking up throttle cable from Ls1 to original 67 camaro
What's the easiest way to hook up a throttle cable to my 67 Camaro using my original gas pedal? Pics are always great!
Old 10-20-2013, 04:31 PM
Indyjc's Avatar
It's been a few years, I used the 99 Camaro throttle cable with a gas pedal from a 70ish Nova with a 6 cyl. The Nova used a cable. Was a complete bolt in with no mods. Might try the conversions section.
Old 10-20-2013, 07:13 PM
99ssleeper's Avatar
Heres what I did...built a small bracket, used a Lokar LS1 cable, and modified the stock throttle arm on the firewall.
Old 10-20-2013, 10:04 PM
badazz81z28's Avatar
Lokar LS1 cable, hooks right to the pedal. I have one on my 78 Camaro
Old 10-21-2013, 07:14 AM
LS1MCSS's Avatar
Unlike yours, his had mechanical carburetor linkage from the factory. His factory pedal setup is nothing like yours. The post with the pic's looks like the way to go.
Old 10-21-2013, 11:35 PM
bmf5150's Avatar
Lokar ls1 cable works perfect
Old 10-22-2013, 08:23 AM
thunderstruck507's Avatar
On my Chevelle I used the Lokar cable. Sleeve runs to the firewall and I heated the pedal arm inside and twisted it to fit the cable. (flat part of pedal arm was parallel to the firewall, twisted it so that it's perpendicular)
Be sure to bend the arm front/back enough you get WOT but it bottoms out on the floor or something else so you don't stretch or break the cable.
Old 10-24-2013, 08:17 PM
Thanks for responding. The pictures are great...very helpful!
The following users liked this post:
Vette-byrd (05-28-2020)
Old 10-25-2013, 08:11 PM
I like what you did..it looks great but I don't have the clearance the way you did on the Nova on the 67 Camaro.
Old 10-29-2013, 05:08 PM
What type of gas pedal (from what kind of car) fits with the Lokar cable? I have a 67 Camaro. Anyone have any part numbers for the Lokar cable?
Old 02-18-2019, 03:32 PM
Gus K's Avatar
Default Right part number to the throttle cable ? For the LS1?
did you ever find the right part number ?
Old 02-18-2019, 05:14 PM
Received 3,021 Likes on 2,352 Posts
Five years later??? Really? Call Lokar.
Quick Reply: Hooking up throttle cable from Ls1 to original 67 camaro
