Crankshaft Pilot Bearing
I just got my LS1 together and was checking the torque converter pilot fit to the crankshaft and have a problem. The pilot barely goes into the end of the crank, the crank appears to have a large steel bushing or adapter in it that will not budge (tried pulling with a home made puller and also the old fill with grease and a socket routine) I bought the crank used so I have no idea what it was out of and its all together so I cant get the casting number either. Here is a picture of it.
[IMG][/IMG]
Anyone ever see anything like this and does this come out?
Thanks
[IMG][/IMG]
Thanks
You can clearly see the lip at the base. I've never seen a pilot bushing look like that but I'm not a big M6 guy. If its obstructing the converter hub it must be removed.
