Did I mill my heads too far?
I have flat top pistons with valve reliefs and running with a MS3 camshaft. Now the heads are Ls6 Prc stage 1. Before I had the heads milled they cc'd them at 62cc. The heads now are milled .035. Is this going to work or did I make a mistake?
If the heads were at 62cc and you had them milled .035" more, I think that puts you around a 57-58cc chamber. what are you planning on running for head gaskets? Also how deep are the valve reliefs? How far do the pistons stick out of the bore at tdc?
I will use the GM stock MLS gaskets and the top of the pistons are flush at the top of cylinder at TDC. I don't have anything calipers here with me now to measure the valve reliefs but may be the picture can give you some idea. Hopefully
Ok i measured with a scale and the intake relief is 4mm deep at the deepest point. The top of the pistons have the number 6398f3905 engraved in them. Its a Texas Speed short block 347.
If you don't have the propper tools to measure, I would give Texas Speed a call since its their products you are working with. They should be able to give you a good idea of about where you are at in terms of clearances.
I did call them and ask but they were no help. They said they lost all there records in 2011 and said they couldn't help me. I bought my short block in 2010.
Were not talking about your relief size, you need to measure the distance between your valves to the point where they almost touch your piston inside the relief..
Some people will say just run it, but its good practice and peace of mind to check for yourself. That way you have no doubt...
The correct answer is to assemble and check PTV clearance. I honestly think you will be fine. If you didn't have valve reliefs, I would be concerned. Since you do, I think you will have enough clearance.
Super Hulk Smash
Why did you mill it so much? That puts you around a 55-56cc chamber... If it was 62cc before, they were already milled some. Of course, if the motor is zero decked, 56cc is about right and puts you at 11.8:1... just like me with 58cc and flycut pistons with pistons out of the hole .007".
And you can check PtV with playdoh. Put the playdoh in the relief, install the head on the engine with the old stock gasket and turn the crank over by hand. Pull the head, use a razor blade to cut the playdoh in half and then measure the thinnest point. Also check to make sure the radius of the valve didn't contact outside of the relief.
This is not the most sophisticated method, but it'll work for you.
Super Hulk Smash
Well, you want to compress the gasket best you can to get an accurate measurement. Once you compress a gasket, I prefer not to reuse it. So you could try without a gasket since your block is zero decked and won't have to worry about the piston coming in contact with the head. If you clear with that, you know you are fine + an additional .051".
