Potential piston to valve clearance issues?
Planning to send my 243s to TSP or TEA for stage 1 of one of the two. But the heads I'm planning on running are an extra set I have that are milled .030". The cam I'm planning to run is a comp cam 228/230 .571/.573 112 LSA. Should I be worried about piston to valve clearance issues?
Yes I have two sets of 243s. I'm asking because I don't know if I should send the stock ones in or the milled ones. Especially since I'll probably end up milling the stock ones if I do send them in. My train of thought is that it would be easier to sell stock 243s vs .030 milled 243s
With a 228/232 .615 cam I had .120 and .100 clearance with .010 milled heads. I had them milled .030 more to cut my clearance down to .090 and .070. You should be fine.
Man, why do people insist on doing things backwards?
1- install and degree cam at desired ICL.
2- Install heads you wish to run
3- measure ptv
4- Decide if clearances reasonable and then mill accordingly
5- measure ptv again after desired chamber volume and SCR reached. Watch ur DCR for type of fuel used.
3- measure ptv
3- measure ptv
3- measure ptv
Then you are not ready to mod if you do not wish to spend the time, money and effort to do it right.
01ssredA4 did not give an answer for YOUR motor, he told you what you wanted to hear and now you 'feel better'.
Good luck!
Good luck!
No, I gave him a ballpark. While I can't promise him my results one can make a reasonable deduction that his results would be similar. How similar? Who knows exactly, I didn't know so I measured and I have results to share with him. Weird circle of life we follow ain't it
The problem is that he is not going to measure and he will be taking multiple 'ballpark' guesses.
Well I've seen the results of such assemblies and sometimes it ain't pretty.
Well Pred that's his choice. He has been warned and I will again: MEASURE to be safe. But in the end people do what the hell they want. I'm not losing sleep over him not listening!
Pred is right .. Measure measure and measure again.. Mill the heads or whatever then flycut if need be, pretty simple.. But I wouldn't wanna take the liability if saying yes go for it.. Results may vary.. You could muff up the alignment of the cam and it don't matter anyway.. You gonna bend ****.. Measure your pushrods too!!!!
3- measure ptv
3- measure ptv
Another thing I'll throw in there is to measure the piston deck height at TDC, and factor that into the comp ratio, quench, and gasket thickness parameters.
If so then I should not have a problem unless the cam I have has been ground way off which I doubt.
For those of you who keep saying measure measure measure, I understand the importance of this, trust me more than you ever know, but the reality is that there is nothing special about my build. It's off shelf cam and off shelf head with common milling, porting and valve job. I think it's logical to gage the forum for this answer.
If you look at the quoted setup, it is a considerably more aggressive cam and milling. Remember my cam is a 228/230 .571/.573 112 LSA
