After a long day of driving...knock knock knock
I've owned this T/A since new and it has always started knocking or pinging after a long day of travel. I'm talking 8+ hours of driving. It sounds like if the gas was 87 octane or something low but I always use 93. It never makes these sounds the next morning or even after a 4 hour drive, just long interstate or cruising days. Only 35k miles on this completely 'stock' machine, and like I said, even when the car was new with ultra low miles on it, it would make these sounds. You mostly hear it during acceleration. The car has been around for 12 years now but I just wonder what causes this. It's never a pleasant sound to hear. I used conventional oil at first and synthetic for the past 5 years or so. No difference. I also use Techron or Lucas products every so often to keep things clean.
Mines kinda the same way. I wouldent call me a knock but sometimes itll make somekinda noise thatll just make you say WTF is that. Ive tried different oils. Not much difference. Its been this way since it was new. I got the car from my parents so its been in the family since new. After the cam install and new oil pump it still has the same thing. I don't even worry about it any more. Back when it was new the dealer said it was piston slap so im just gonna roll with it. Its made it this far and is still together so its gonna roll until its had enough.
OP you can pop your valve covers off and take a look at your valve train!
My 114,000 mile original engine was making noises but still drove good and I popped the covers off and a rocker was laying sideways and the pushrods looked like a 7, I'm not saying its your problem but definitely worth a look..
You can start with this and cross things off and rule things out!! And it only take 15-20 min
I appreciate the responses and advice but my skill levels don't exceed anything more than oil changes and similar maintenance. I doubt the engine would have mechanical issues ever since I drove it off the showroom floor. As I said, the engine has always done this but just after these rare very long days. I've talked to different mechanics and each one stated 'don't worry about it' unless an SES light comes on or the sounds don't go away. If I take the car on errands today there will be no knocking sounds, but I bet if I took a long trip to Raleigh and back, I'd be hearing those knocking sounds at the end of the day. Mostly curious to hear from others. Thanks!
Did you ever redline the engine prior to hearing the noises?
Run it super low on oil? I'm talking 3-4 qts low
I know I'm being extreme but its a possibility
My car is making similar noises and was redlined by the previous owner and he bent a pushrod since then the pushrods have been changed. So now I'm stumped. I posted a thread with a video.
Sure, I've floored it sometimes but NEVER manually shifted through the gears, just let the A4 shift itself. I'm sure the car is made for some of this type driving without damaging itself. I hope so anyway.
I wouldn't think it was anything serious but if you're really concerned you would need to start taking things apart to eliminate things it could be such as rockers, pushrods, lifter leak down; etc.
