Fresh Block from Machine Shop
Old 11-05-2013, 04:22 PM
obfpd172's Avatar
Default Fresh Block from Machine Shop
I have some questions on the Ls1 block I purchased this is my first attempt at the ls based engine build. I have a 2001 ls1 block I bought that is from the machine shop along with the block I have a crank, what I believe is a set of rpm forged rods with arp bolts, and a set of probe forged pistons all the rotating assembly is balanced. I have been reading on the oil galley plugs and coolant plugs but keep coming up with several different part numbers and quantities / locations. The local gm dealer was little to no help on what I need. Any help would be great also I was thinking of ordering a manual to assist in this process like building and modifying ls engines
Thanks Bobby
Old 11-05-2013, 05:38 PM
Treyvs's Avatar
Get with Texas Speed and Performance for the galley plugs and coolant plugs, and don't forget the "barbell". As for the manual, the book that I refer to is "How to Rebuild GM LS Series Engines" by Chris Werner, and it has helped me with my build.
Here is a link: http://www.ebay.com/itm/Rebuild-GM-LS-Series-Engines-All-Generation-III-IV-5-7-5-3-6-0-6-2-LS1-LS6-/310612313298?pt=Motors_Car_Truck_Parts_Accessories&hash=item4851efc4d2&vxp=mtr
I hope this helps, and good luck!
Old 11-05-2013, 09:39 PM
LilJayV10's Avatar
This is also a good book. Very informative.
How to Build and Modify GM LS-Series Engines (Motorbooks Workshop): Joseph Potak: 9780760335437: Amazon.com: Books How to Build and Modify GM LS-Series Engines (Motorbooks Workshop): Joseph Potak: 9780760335437: Amazon.com: Books
Quick Reply: Fresh Block from Machine Shop
