04 ls1 cam upgrade
04 ls1 cam upgrade
Hi every1 I wanted to upgrade my cam in my 04 ls1 I was thinking aboutCOMP Cams K54-412-11 - COMP Cams XFI RPM Cam and Lifter Kits if I do what else will I need to upgrade?
Depending on mileage here is what I normally suggest for any cam swap.
-Cam
-Lifters
-Lifter Trays
-Timing Chain
-Depending on mileage and oil pump is a good idea
-New harmonic balancer bolt, and all the gaskets.
-If it is a large cam, a trunnion rocker upgrade kit would be a great idea.
Not all of this may be needed but that puts a blanket on most of everything
-Cam
-Lifters
-Lifter Trays
-Timing Chain
