Lq4 with l92 heads
Old 11-21-2013, 07:15 AM
Kevs01's Avatar
Default Lq4 with l92 heads
I have a lq4 that im rebuilding and putting l92 heads on it. Which cam to go with? It's a daily driver, circle d 3000-3200 stall, 3.73 gears, cai, and long tube headers. I hear I need to watch for valve clearance as well.
Old 11-21-2013, 09:20 AM
Cwarta's Avatar
In the rectangle heads it's crucial to pick the right cam. Valve events are extremely important gear for flow/port valocity. Much more to be lost than gained with an off the shelf cam and these heads. Call fti or Martin at tick performance for your needs, just a touch more than a shelf cam anyways.
Old 11-21-2013, 09:29 AM
95wannabe's Avatar
I went with Geoff at EPS for a custom grind cam. Engine Power Systems
Search should result in several threads for him.
Almost same exact setup as yours, except my car is a OBD1 car so I have to pass an idle emissions test.
Still a few weeks out on getting it all together but hope to have some results soon.
Old 11-21-2013, 10:03 AM
Kevs01's Avatar
Ok. Thanks for the helpful info and recommendations.
Quick Reply: Lq4 with l92 heads
