Horizontal Score In Cylinder Wall??
Just pull the heads off my 80K LQ4. Purchased engine over a year ago and it has sat until this point. I've never fired the engine so I don't know what compression was prior. I can definitely feel the score when I run my finger nail through it but it doesn't "Catch". All the other cylinders look good with cross thatches visible.
I normally have seen vertical scratches. Any idea what would cause this?Should I take this to a machine shop to look over?
Should I be not as concerned since the scratch is horizontal and not vertical?
I remember a magazine article where they boosted a 5.3 to over 1300 hp and it was a jy engine w one of the cylinders having a pretty bad rust patch in the cylinder they couldnt get out. point being, wont last forever like that but also will run for a while and effect performance to much
Thanks Guys. I think I will just button it up and see what happens. At the very least I want to get the car running and off to the bodyshop. If I don't lose compression then its a plus.
