CNC 243 with hot cam
Old 12-04-2013, 01:32 PM
02fbody35th's Avatar
Default CNC 243 with hot cam
So currently I'm running the gm hot cam and I really like it! It makes good power and tons of tq. It put down 370/370 to the wheels which is respectable. I have a set of 243 heads that I want to send out to AI to be CNCd and milled. Anyone have any thoughts on this combo? What kind of power I'm prob gonna be looking at? I really want to keep this cam. I'm aware that there is prob better ones for this combo. But this cam meets my needs. So what do you guys think? Any h/c guys out there with hot cams, please share your thoughts
Old 12-04-2013, 01:58 PM
HCI2000SS's Avatar
Since you already have the heads i'd say just go for it. Depending on how much they are milled, compression, etc...you might get around 30-40 hp which would be great
Old 12-04-2013, 02:06 PM
Nice! That would put me around 400-410 rwhp which sounds decent to me for a smaller cam
Old 12-04-2013, 02:08 PM
HCI2000SS's Avatar
Yep, and with that cam it should have a nice broad powerband. What rpm do you shift at right now?
Old 12-04-2013, 02:12 PM
Right now I shift at 6000rpm
Old 12-04-2013, 02:15 PM
HCI2000SS's Avatar
Where does that cam peak? I'm just curious because at 6 grand is where most stock cammed LS1's would shift
Old 12-04-2013, 02:18 PM
Uhh I'm not sure I have to check my graph. I usually just play it safe and shift a 6000 my limiter is at 6400 I believe
Old 12-04-2013, 02:21 PM
HCI2000SS's Avatar
Gotcha! Well it might benefit you to shift a tad higher. If the limiter is at 6400 i'd try 6200 and see how that works
Old 12-04-2013, 02:39 PM
Will do thanks!
Old 12-04-2013, 07:47 PM
TXZ28LS1's Avatar
My buddy runs the hotcam with unported 243 heads and made 400 rwhp.
Old 12-04-2013, 07:51 PM
Good to know! That would mean with ported and milled versions I should be upwards of 400rwhp. Which is right were most other guys with mild h/c setups run. I just don't understand why this cam doesn't get more love.
Old 12-05-2013, 10:47 AM
gagliano7's Avatar
I always wanted to know how this cam will do in a 5.3. Can't find any numbers. How is the torque with this cam compared to stock?
Old 12-05-2013, 01:48 PM
The torque curve is my favorite thing about this cam. It comes in very early and maintains it all the way up. I have to find my graph to post it
Old 12-07-2013, 11:58 AM
Anyone else have any results with the hot cam and ported heads?
Old 12-07-2013, 12:04 PM
mac62989's Avatar
Im interested in seeng the cam only graph
Old 12-07-2013, 12:54 PM
Here it is
Old 12-07-2013, 02:23 PM
HCI2000SS's Avatar
Originally Posted by 02fbody35th
Here it is
That is a beautiful torque curve! I can now see that your peak hp is about 6k, so i'd definitely try shifting around 6200 if I were you
Quick Reply: CNC 243 with hot cam
