Bare minimum cam swap!
What's the bare minimum parts I can get by with while doing a can swap on my LS1. I know the gaskets, springs, and cam, but if I just want to get it in and back running should I need new push rods or anything else to make it work right? The cam is a custom grind, comp cams 232/236@50 542/545 on a 112. Also I was wondering if anyone had run a cam similar to this one. Thanks
Depending on the mileage on the engine, and how hard it's been driven, you might want to also consider a new timing chain and oil pump. You can get by on the stock push-rods if there's enough lifter preload with the new cam, otherwise stiffer longer push-rods should be on your list.
Gaskets, springs, valve seals, cam, coolant, oil, oil filter, pushrods, a/c recharge (if you have a/c) and a tune minimum. I wouldn't run an aftermarket cam and springs with stock pushrods and it is critical that you check the pushrod length and get stiffer springs. You also need a tune. Every time I have ever torn an engine down to install a cam I planned on figuring a little extra money for incidentals just in case (spark plugs, etc...). Unless it's low miles I don't see why you wouldn't replace the timing chain and oil pump also though.
Its running good now but I have dogged the **** out of it. I'm just trying to use all of the parts I had laying in the shop while I'm freshing up the trans. Its a stock car now but I'm about to put in a 4000 converter, long tubes, a 3.5" exhaust, and a 3.73. I've got this cam sitting here that I wanted to use but I'm getting ready to build a new motor so I didn't want to spend much on this one. I hate to waste money on stuff I won't need but about 6 months. I was mainly wondering about the push rod issue.
The push rod thing is kinda a tricky one. I installed a cam into a 2004 4.8l and it needed .050" longer pushrods, I installed the same cam in a 2002 6.0l and stock length pushrods were perfect. So I'm pretty sure it depends on your particular engine, since the 2 engines I listed should have been the same.
You'll need to measure for push-rod length and then get at least .080 walled ones.
PS: The stiffer the better, (less flex), more accurate cam timing and more powa.
