Cam Question in 5.3l
I purchased a 5.3l block for my swap into an 82 camaro and the guy "threw" in a ls1 cam for free. My question is how will this cam work in 5.3l and is it worth putting in or getting a custom grind. I've looked up the part and grind # to no avail. I know a little bit about cams but not that much and I find it weird the intake and exhaust are the same? and what kind of hp gains could I expect over a stock cam or another custom grind?
Specs: part# 54-000-11 grind#: 13117r/13117r
gross valve lift: I-.598 E-.598
Duration @ .006 Tappet lift 275 275
duration @ .050 I- 226 E-226
lobe lift I-.3520 E-same
Lobe separation 113.0
I just put a LS1 cam in my 5.3 but have not tried it out yet. Car craft did a cam article and the LS1 cam made 50 hp more on the top end but lost 28ft/lb torque around 2800.
So this is a stock ls1 cam? i thought it might have a custom grind to it :/ dang it lol. And this is a car that I want to be fast from stoplight to stoplight which is all about the torque so I don't really want to lose the torque :/ guess I'll be getting a custom cam then. Any suggestions that are good for gains now and turbo friendly?
LS1 Camshaft Specifications
1998 - 2000 Fbody
202/210 int/exh @ 0.05" duration
0.496" / 0.496" int/exh lift
116 LSA 2001 - 2002 Fbody
197/207 int/exh @ 0.05" duration
0.467" / 0.479" int/exh lift
116 LSA
2001 LS6 cam
207/217 int/exh @ 0.05" duration
0.525" / 0.525" int/exh lift
116 LSA 2002+ LS6 cam
204/218 int/exh @ 0.05" duration
0.551" / 0.547" int/exh lift
117 LSA
1998 - 2000 Fbody
116 LSA
2001 LS6 cam
117 LSA
Super Hulk Smash
One cam I've always liked in daily driver LS1s or 5.3s is the EPS 222/226...
EPS has a 222/226 .597"/.598" 115+3 using EPS lobes (which are endurance type). It has made 430rwhp with stock unported LS6 heads.
https://ls1tech.com/forums/dynamomet...k-results.html
390rwhp stock heads:
https://ls1tech.com/forums/dynamomet...241-heads.html
Another 390rwhp with stock heads:
https://ls1tech.com/forums/dynamomet...3-results.html
430rwhp with PRC 5.3s:
https://ls1tech.com/forums/dynamomet...p-410rwtq.html
I'd do that cam.
I'd do that cam.
