German Castrol oil thoughts.
So I need an oil change and started searching the forums about oil preferences. I kept finding a lot of threads/posts about German Castrol (also known as GC). Problem is that most of these threads were quite a few years old. I went on a search to find this oil which was a 0W-30 made in Germany. The only thing I found was a European Formula Castrol Edge with Syntec technology in 0W-40. This oil says made in Belgium instead of Germany. Just as good or crap? I also purchased a Wix 51522 extended filter (for 6.0L trucks) for extra filtering media. Should I use what I bought or return it and get more?
That will be basically the same stuff just heavier warm weight
The old "German Castrol" is still available in some places, it will be in the same bottle like you posted but will be 0w-30. It is available here local at both Autozone and Advance.
I run it exclusively in my car ever since I first tried it. The valvetrain noise went down noticeably. It is also often on sale for $29-32 with filter for 5 qts. Advance also often lets you pick up an extra qt for the sale price.
Honestly why people get a fuzzy feeling over a certain oil is complete and I mean complete all in your head. I use the cheapest Quality oil I find on sale at walmart, usually Pennzoil yellow bottle. 10-30 in all my engines and have never had any failures related to oil. Jeep has almost 300 thous miles on it.
The "German Castrol" is on the thick side of a 30wt oil SO any engine is a little quieter using thick oil it may sound a bit quieter. NOTHING ELSE. Its not gonna last any longer or run any better. It just a waste of your resources.
I never heard a quiet LS engine...THERE is No such thing.
If you want to use a thicker oil just buy 10-40 cheap standard oil and WALLAA same placebo effect. The engine sounds different so it must be good now I feel fuzzy inside.
Better than what? I'm not trying to start a argument just been down this oily road too many times. I never seen ANY oil that saved a engine from anything, If you are going to run on the edge and think the oil will save you from disaster you need a different hobby. ANY good standard off the shelve oil will protect as well as the Castrol will. Do you actually think they know more than the other major oil companies?
I'll tell you the secret to a long lasting LS engine, keep the oil overfilled and check it often. I always run 6 1/2 qts and check it every 500 miles. Most LS engines use a lot of oil and even one full throttle run with low oil will do damage.
The cheapest synthetic from Wal-Mart is their house brand and if I bought a jug of it and a filter it would be the same price as the oil that shows to be better for the engine in oil analysis. So why not?
You are right though, oil level and keeping it clean are what matters more.
RockinWs6 there is so much wrong with your post I do not know where to start. I good oil will give a much better oil film that will protect your engine at high RPMs than a cheap oil. A good oil filter will will give good flow which is what a LS engine likes. Castrol GC will give much better oil analysis than most other oils. You do know what an oil analysis is?
Oil is all BS, buy the chgeapest major brand and keep it clean and full. There is NO other way. You can full your crankcase with what ever flavor of the week everyone is using but in the end clean and full wins.
Now if you are talking oil change intervals that's where certain oil are much better than others.
I use the synthetic and change it 5-7k miles depending on what the car has seen in those miles and how it looks. How it looks might not be the most scientific method but regardless, if it gets black and nasty looking sooner I change it sooner.
Hence the synthetic, I have enough old school mentality I wouldn't want to run standard oil that long in a performance application. My truck gets the same interval posted above with standard oil (whatever brand is on sale), but it also doesn't get beat on or revved even close to redline.
I use Pennzoil yellow bottle for about 20 years now 10-30 with a Purolator filter<NO ECORE> usually go 5k-6k without any issues. Even my old jeep with the old flat tappet cam in it has almost 300k miles on it and runs like new, No oil usage.
In all my LS engines I use the same without any oil related problems.
That's MISTER MODERATOR
German Castrol 0W-30 has a very high shear and temperature breakdown rating. It's highly rated over at BITOG-and those guys are reallyREALLY **** about their oils.
I'm not sure about the 0W-40.
I use it in everything I own and use it in every friend's car that I maintain.
I have about sixty quarts on hand-all from the sales at Pep Boys and Auto Zone.
Wix is an excellent filter-and if you can use a tall one, even better.
When I need an off the shelf oil filter, I reach for a Mobile1 Extended filter. My vehicles use Fleetguard filters. I'm pretty **** about my lubrication too
