Cometic .060 Gasket for 5.3 L33 Build?
Hey all,
Just got my short block back from the machine shop. It needed to be decked and now I have the pistons coming out of the hole around .018-.020 on average.
I want to run the .060 Cometic gaskets to get a proper quench distance of .035-.040, so my question is this...
Will the C5475-060 gaskets with the 3.910" bore be the ones I need to get?
Also,
I have read of some people having sealing issues with these. From what I can gather the surface of the heads and block need to be at a smoothness of 50ra or better. Both my heads and block are fresh from the shop and look good.
What does a surface finish of 50ra's look like? I have nothing to compare to...
Also, would you all recommend a light dusting of the copper spray to the gaskets even though Cometic says to install dry?
I have read of people installing them both ways...
Thanks for any help or insight!
Also,
Hey all,
Also,
Also,
