which heads to buy
Old 12-17-2013, 11:36 PM
02ssick's Avatar
Default which heads to buy
Before summer I am going to do a heads cam swap (since I have a lifter making noise) just curious what you guys think. I'm leaning towards the 2.5 ls6 heads with the ms3 cam from Texas speed. Should I get those heads milled? Should I just go with the 5.3 heads? Also what about oil pump/timing chain? Annnd lol what about injectors
Thanks for the input!
Matt
Old 12-18-2013, 11:19 AM
Sales1@Texas-speed's Avatar
The 2.5 LS6 cylinder heads are a great way to go with the MS3, but we will have to keep them at a standard chamber of roughly 64cc to insure proper clearance assuming your still using the standard LS1 piston. If your wanting to bump compression and you have an extra hundred to spend I can get you into our PRC aftermarket casting 225 As-Cast cylinder head that features a thicker deck, larger valves, laid over valves for increased piston to valve clearance, and a standard chamber of 62cc which offers us a bump in compression right from the start. I've posted a link to this particular cylinder head below. Feel free to give us a call for any help with your setup.
http://www.texas-speed.com/p-3515-pr...ral-heads.aspx
Old 12-18-2013, 08:53 PM
02ssick's Avatar
Alright sweet thanks! What do you think about injectors I should probably be upgrading them as well
Old 12-18-2013, 09:11 PM
HCI2000SS's Avatar
I'm running the PRC 5.3 heads with a cam very similar to the M4, and it runs very strong!
Old 12-18-2013, 09:40 PM
garygnu's Avatar
get the prc 225 cast heads ,thats a good deal !
Old 12-19-2013, 09:51 AM
I would recommend the FAST 36lb injectors. They should have no problem supplying your setup with enough fuel. I posted a link to them below so you can take a look.
http://www.texas-speed.com/p-174-fas...ons-legal.aspx
Old 12-19-2013, 11:10 PM
02ssick's Avatar
Do those heads come with valves? Thanks for you're input everyone!
Old 12-19-2013, 11:34 PM
02ssick's Avatar
Are you running on stock injectors?
Old 12-20-2013, 09:14 AM
HCI2000SS's Avatar
No I run Bosh 42's
Old 12-20-2013, 09:34 AM
They do come with the valves standard.
Old 12-20-2013, 10:13 AM
BrntWS6's Avatar
I would go with 42lb injectors also, I'm running 42's and at 80% duty cycle. The price difference isn't that much either.
Old 12-20-2013, 01:03 PM
Rise of the Phoenix's Avatar
Always go at least one size higher on injectors than what you need.
Quick Reply: which heads to buy
