Keep fast92 or get a 102
You would pick up more if it was a larger cubed motor for sure. You do have good heads and a healthy cam though so may pick up 10hp? I don't think it would be worth the cost to change. Just spray a jet size larger....much cheaper lol
LS1Tech Premium Sponsor
It depends on how much you picked up from your porting. Leaving that out, I doubt you pick up more than 10hp.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
With the exception of electric throttle bodies, I haven't seen that to be the case. Perhaps its been poor tuning.
__________________
