Time for a new top end..
For the past week shes been idling rough and surging a bit more while sitting still in drive and even in neutral some times. A couple nights ago, I was in a high rpm, high g force situation, and I'm thinking the top end got starved of oil. After I slowed down and started driving again, above 2k rpm I could hear a knocking. Got out and listened, its coming from the top end, it gets faster and louder with rpm. She still drove perfectly fine for the most part. Later in the night as I was trying to limp her home, she died on me coming to a stop for a red light. Started her up and took her to the on ramp to pull over and got towed home. The battery died after 45 minutes of waiting for the tow, once i get it charged im going to pull codes to see whats up. I figured as long as I didnt hurt the bottom end I might as well do a cam swap. What do y'all think might be the problem? Bent pushrod? Collapsed spring?
Also on another note, money is tight, I figure if anything needs to be swapped I might as well do a cam swap while I was in there, but it might be a little while before I get the necessary supporting mods (intake/exhaust) to go along with it. I'm still on stock manifolds, but I already have a torque converter. Would it be Alright to swap the cam on stock manifolds? I know it will probably be a dog but might as well do it now you know.
Ok almost done with the drivers side valve cover, but there's a pipe way on the back of it that comes out on top, a little over an inch in diameter. What is this pipe and can I just take it off?
