F-14 Or VRX5 cam
F-14 Or VRX5 cam
looking to hear what everyone thinks about which cam to go with and why, The car is an M6 going to end up getting fast 92 intake, and 92 TB, in the future ill be looking to be running nitrous.
Thanks for everyone's input.
98 TA- SLP cold air intake
LS6 intake
Pacesetter LT headers 1 /34
Pacesetter Off Road Y-pipe
SLP powerflo catback
LS6 intake
TFS 220 VRX5 Z28 Idle Video
Awesome cam. If I had the money for lower gears at the time, I would have opted for the VR Vindicator instead. Still, no regrets. The VRX5 has great drivability and fairly linear power for the size. This is with 3.42 gears.
If I remember correctly Futral has their cams ground through Cammotion I believe, Vengeance uses Comp. My Vindicator and most of their cams if I'm not mistaken use Extreme Energy lobes. I would check on that, of the two I like the F-14. However, the Tick Performance SNS Torque Max stage 2 gets my vote. It also uses a much more forgiving lobe set, with the option for an even milder set-up to extend the life of your valve springs even further.
