Advice on Cam Package
Hey,
i have a 99 z28 A4 with a CaI,Lid, slp maf, PP TB, LS6 intake and mac mids and catback.
I would like to add a Cam. I was going to get heads but didnt know i needed a stall. goal is 400-420 rwhp on a budget
this is what i put together. Let me know if this is compatible and your thoughts and if i missed any thing.
comp Cam 224/230 cca-54-426-11 -400
Trick Flow® Track Max® Pacaloy Valve Springs TFS-16918-16 -130
Trick Flow® Billet Steel Timing Sets -TFS-30678533 -130
Texas Speed Ported LS6 Oil Pump w/ O-Ring -190
Trick Flow® Chromoly Pushrods TFS-21406850 -100
Yank Stealth Thruster Converter 2800 302-ST-XXX -475
GM Replacement LS7 Lifters 12499225 -140
thanks
thanks
Converter is too small. Go 3400rpm or more. Also autos do not dyno as high especially with a converter and with out long tub headers so you will prolly not make you goal but will run with 6spds of that power level. I do not know anything about the springs you have selected what is the lift rated at for them? Also what's lift of cam?
If you do heads and go with more cam you should be able to get there, cam only will have to be a max-effort cam with everything else optimized!! As for the converter I'd go with at least a 4000 stall and for gears either 3.73s or 4.10s on a 26" tire! Just my 2cents, GLWTB Larry.
+1 on the converter. I ran 3500 stall on a daily driver without any issues.
Don't forget that you can run more compression with a lot of overlap. Need to check dynamic compression.
We are having a Christmas Sale on our cam packages until after new years sometime if you haven't bought your parts yet.
Our kit comes with the following:
Comp Cam
Brian Tooley Racing .660" Dual Springs w/steel retainers
Brian Tooley Racing Chromolly Pushrods
The kits retail for 679 but we are offering them for 654 shipped with our sale. We also offer our ported oil pumps for 129 when added on to the cam kit. (retail is 149)
These kits also come with a free HRI tshirt and stickers
PM me if I can help in any way!
Ethan
HRI
Comp Cam
Ethan
HRI
