Running stupid Rich after 228R Cam install
Okay folks, like title says.
I installed TSP 228R Cam along with a newer set of 241 Heads from a vette with only 20k miles (not happy about having to do that either, previous owner had unmatched 241's on car). Did whole nine yards, ported oil pump, springs, etc. TSP Tuned my PCM and I have not had a single check engine light. The car is running great it didn't fall on it's face or anything even the initial start. The biggest problem I am having is my MPG is like 9/14. With a full tank of gas I got 220 miles. About 180 of those miles where all highway doing 80 MPH in sixth. The car has no cat's and headers with xpipe and custom true duals but I can smell my fuel bad. Like don't stand behind the car or you will instantly smell like exhaust fumes bad.
I am thinking about calling TSP which I am sure one of you guys will chime in but I wanted to let the PCM dial in to the car and I did wait for the cam to break in before romping on it (about 300 miles) but I did not change my driving style at all (used to get 300-320 to a tank). Is this a simple tuning problem or is this common after internal mods? I did pull two plugs (ngk tr55) and they have white spots on the ground electrode and pretty black at the base (brand new plugs when I swapped heads).
It says right n his post that he has a mail tune from TSP. To the op a canned tune for a cam isnt meant to be a total fix. You still need a real dyno tune the mail one will get you to the tuner but its not meant to be the final tune. That could be the sole contributor but also check for a vac leak or slow o2 sensors if all that checks fine you need a real tune.
Well Nick D here I come. Really wanted to hold out for some heads but the prices of 243's are going for like 600-700 dollars unported in southern arizona, thats friggin insane.
Nope still running the stockers, I did clean them up really good before mounting them back on the intake but thats it as far as the injectors go.
Sprayed MAF did another browse around engine bay. The PCV Valve hose that starts at the driver side valve cover is stupid loose like I can easily pull it out, anyone elses like that or think this could be causing a vacuum leak. The grommet is still there just wondering if constant installing and removing made it too loose.
Yeah I think the car is running amazing IMO, the tune is just making it drink gas. Using torque pro the other night I did first 0-60 pull in 4.9 seconds with an altitude of 4650 ft and a bit of wheel spin.
Also have a 112 LSA, maybe a 110 would have helped that a little bit more.
If you are smelling fuel that bad at the back of the car....Guess you are washing the bores nicely with fuel.
Get it dyno tuned before you wreck it.
