Head work suggestions.
Suggestions- 00" silverado 5.3. Comp cam 222/224 .566/.568 @ .50, beehive springs, chormoly push rods, stock intake.
I was wondering if I could mill the heads, or port and polish them if this would gain me anything. I still want to have good low end torque.
Why not contact one of the site sponsor for your specific needs?
If you want to work with the factory 5.3L castings Richard at WCCH has an affordable option that works well for a truck set up to maintain the low end tourque. http://www.proheads.com/pricing.html
I believe TEA also does the 5.3L heads. http://www.totalengineairflow.com/cu...gm-2/5-3-gm-ls
You maximise the flow in this area by removing restrictions and sharp edges like were the seat meets the bowel. These cause airflow restrictions.
Read up on Porting. AGearHead4Life has some youtube video's on porting your own heads. He also has a DIY thread on here.
https://ls1tech.com/forums/generatio...-can-help.html
Super Hulk Smash
Most of the power achieved is actually from the valve job. The port just enhances the valve job by allowing optimal airflow...
I would go with a proven CNC port/valve job combo from TEA, AI, WCCH, or hand porting from Chris Frank, Greg Good, or Larry Meaux. Any of those companies/individuals can set your heads up for you to work very well.
Local shops haven't spent the R&D to develop the ports and valve jobs the bigger LS shops have done and don't have the proven results. In the end, the price difference isn't much, but the results can be very different.
The following users liked this post:
G Atsma (11-08-2019)
